I've owned my 1981 R100RT for 22 years. A few days ago, several electrical things failed. 1) no turn signals, 2) no brake light (but running lite OK, 3) No horn, 4) dash voltmeter doesn't work. As far as my analysis of the circuit diagram in Clymers for my bike, it appears that all of these items are connected through a single fuse. Unfortunately I can not find the two fuses (fuse block) as described in the book or by a friend who is sure the fuses are in a block under the air pump tube. I do not have a fuse block there or anywhere under the tank or near the battery. Any suggestions? Do you agree that it could be a fuse? Thanks rtrenndowski@verizon.net
