I don’t think the “choke” is hooked up, I get no resistance and notice no change when adjusted. Haven’t really had to use it much, it’s quite warm here.
Good to know, I was reading people say you don’t adjust iridium plugs. Got a good deal through work so got them. Guess I will check and carefully make the adjustment.
Book says .8mm, I’ve read .031” which I think is almost the same. Then I’ve read .04” somewhere worked better for a fellow?
Get that "choke" cable adjusted properly. I have a feeling this is one of the sources of your problem.
Until you get the bike to start on demand your plug gap should be about what the book says. After that, you can start experimenting. And yes, you had better ensure you have good contact between the stick coil and the plug.
