Airhead oversize brake rotors
klmoto
Fisrt time post,
Has anyone fitted the 285mm rotors, for use with later Brembo calipers, to a snowflake wheel that was originally fitted with the 260mm rotors? Four bolt vs Five bolt. I'd like to fit a 1992 front fork to a 1979 R100 and use the snowflake wheel. I know I will need to modify / bush the front axle.
And the upper and lower triple clamps
And the rotors or the wheels
And probably you'll need a different master cylinder and that means converting to bar-mounted master cylinder.
Airhead Oversize Brake Rotors
Thanks Kent,
Have the bar mount master cylinder & triple clamps.
Looking for a source for 285 mm rotors for the snowflake wheel.
Trying to find out if EBC will sell the 285 mm rotors without the 4 wheel mount holes, so I can adapt to the 5 hole snowflake wheel mount.
1st post, 1st reply,
Kevin
79 R100RS
92 R100RS
Other brands
