ultracyclist
Approximately how much does the Airhawk raise the rider from the motorcycle seat?
TIA
TIA
TIA
FWIW - here's a lower cost alternative: http://airventusa.com/ultracool4.htm
I see the primary reason for any sort of seat cover as providing air-flow. When you get air circulating under your arse, you stay cooler and dryer eliminating discomfort. Good wicking shorts are another tool in the arsenal (I like underarmor, but there are many cycle short options and LDcomfort). So I don't see how this pad is going to help. The Airhawk has numerous bladders and air can flow between them, beaded covers have numerous beads that allow air to flow between them, this thing is going to be a lot like sitting on your vinyl seat - no air flow. If the problem is discomfort due to a hard seat, this should help, but it won't help any issue related to heat/airflow. JMO.
TIA
