ridgetopboy
There's a lot of posts about the need to replace the brake lines on older bikes because the rubber ones degrade over time causing brake problems or even failure. I would like to replace my original rubber lines with a set of SS braided lines but I am wondering how that can be done without introducing a lot of air into the system. Is there a specific procedure for changing the brake lines out w/o introducing air into the system? Your advice would be appreciated.
Mark Wialbut
2004 R1100S (ABS)
Mark Wialbut
2004 R1100S (ABS)
