mindtrainer
Tail Light & Parking Lamp (Mini Head light) wont work.
I know that the fuse is good and I replaced the Tail Light Bulb Monitor twice and it didn't help. I know that there is no power at the harness plug going to the tail section for the tail light.
The Tail Light Bulb Monitor is supposed to keep the instrument warning light lit if a tail light does not function. It goes off after applying the brakes just like it normally would.
The Tail Light Bulb Monitor socket connection 58A goes to the tail light bulb When I apply 12v+ here the tail light goes on. Socket connection 31 is ground and I verified that I am getting a good ground and the Bulb Monitor.
I removed and cleaned the multiple ground wire connection under the tank.
Just want to be clear here this is NOT a dead or corrosive bulb, socket, or dirty plug.
Every other light and turn signal works well.
Any suggestions....
Thanks.
Any suggestions....
Thanks.
