Two years ago I picked up this 87 that sat for 10 or 20 years. I replaced the fuel pump, cleaned the tank. replaced all submersible fuel lines in the tank to the rail, cleaned the injectors and got it stumbling along. After buying Mostplus ( https://www.amazon.com/MOSTPLUS-0250150210-Injectors-85-95-K75RT/dp/B07PMVW9L8) injectors on AMAZON it fired up and ran like stink the remainder of that season and last.
This year I can't make it three blocks before it feels like it is running out of gas and if I don't turn around - it gets worse and worse until it hardly pulls my weight. Once home I have to pull the injectors. clean the injector filters in acetone and reassemble. It runs well until I hop on and drive three blocks.
Do you think maybe the return line from the rail and the pressure regulator should have been replaced too? Do you think skungey gunk is finally breaking loose and filtering back through the rail? It seems weird because gas should be going away from the rail and the new filter should not be letting skunge into the rail.
It always seems to be just one injector and it isn't flakes, usually just on injector screen is just dark - can't see light through them.
I need ideas men! Why do i get it clean and it clogs soon after?
