deyoung1983
Hello! I'm new to the forum but hoping someone with more experience might have some advice about an issue I've recently had with my 1983 BMW R65.
About three weeks ago I noticed a metallic rattle when the engine was running (particularly in low gears). Didn't want to run it much hoping to check it out more.
The next weekend I went to start it up and it wouldn't start. The starter motor was clearly turning and getting power, but somehow didn't seem to be engaging the engine. I was able to bump start it (run it in gear with clutch in and ignition on, jump on and release clutch, started right up). So it didn't seem to be an engine issue. Took it around the block a few times but still getting the metallic rattle.
After some research my best guess was that the starter drive/clutch was not properly engaging the clutch carrier (and maybe not entirely disengaging either, thus the rattle). So, my plan was to just replace the entire starter motor (upgrade the original Bosch for a new Valeo).
Ordered the new starter motor, and got it in a few days later. Last weekend I was going bump start it again to get it 10-12 blocks to a shop where I had more access to tools to remove the tank, replace the starter, etc. But, this time she wouldn't roll in gear. It feels like the clutch is stuck. Will roll in neutral, but not in gear even with the clutch in, so couldn't bump it.
I'm now trying to find someone with a trailer to get it to the shop... But, does anyone have any advice or ideas? Does this sound like a Bendix drive issue? Should replacing the starter solve it? Is the clutch issue related or not? Any advice on that? I love my bike but know I would be in over my head with extensive clutch/transmission work.
Thanks! I truly appreciate any advice.
- Ben
- Ben
