2018 rt transmission Breather valve
ah3456
Help ! After doing a final drive and drive shaft lube a rubber piece that fell from the bike as I was refitting the rear tire which later I found out was a transmission vent valve .I did not see where it fell from as i was on the opposite side of the bike. Has anyone here ever replaced or laid eyes on this part and may know its location . thanks
It is a vent piece for the final drive. Mounts on the inside face of the FD unit so you’ll need to remove the wheel to put it back in place. Placement should be fairly obvious once the wheel is out of the way.
Best,
DeVern
