Valve cover gasket leak 2016 RTW, new gasket torqued 10nm, still leaking.
ideas?
If will fit either way but only one way is correct.Yes that darn spark plug gasket will bite you in the rump if your not careful. Good advice.
Reinstalled the valve cover and spark plug tunnel gasket after careful cleaning of gasket and mating surface.
Results perfect.
Thanks for the info.
