desmoderek
MotoDruid
The bottom 1/4"of the screen is hidden behind the plastic dash, making it impossible to read the GPS Dashboard. Is there a way to move the entire cradle up a bit to enable a full view of the GPS screen?
TIA.
TIA.
Do you have the stock Nav IV? The bezel on the 13s is smaller since it was made for the IV. And smaller than the 5 or 6.
There is some adjustment, but not much. Remove the Nav and there are screws on each corner of the chassis for adjustment.
You can get a new bezel. Not too expensive.
That's the best way to go. Had to do it on my 2012.
Sounds like an ideal solution. I think they're under $60 online.
How easy is it to do the swap?
I see two torx screws above the panel, are there other parts that need to be removed to gain access to do the swap?
Just got a 2012 and love the bike, but this is an issue for me as well. I have a NAV V from my 2014 GS and would like to use it on the KGT as well. Any pointers on the best source for this new bezel, part #, and DIY instructions would be much appreciated. I'm pretty handy with doing these kinds of things, just dont't want to go down the wrong path due to not really knowing the bike yet. All help would be most appreciated!
