A few weeks back a spring pothole put a dent in my front rim at the bead. But it held pressure for the 30 miles to get home. When I took a closer look I could see a slit in the sidewall where the tire was pinched, so I replaced both wheel & tire (OEM) at my local dealer.
After getting it home I put it up on the center stand and a front fork lift to clean the wheels. That's when I noticed that the front wheel doesn't spin freely as it did prior to this incident. Looking at the pads it appears that the rotor is contacting the pads with no visible space between. I can spin the wheel but it stops almost immediately after I release it. And there is a noticeable rubbing noise while its spinning. I'm not a mechanic (except for an oil change), so I don't know much about the brake system.
Could this be related to the installation of the new wheel? I would guess that the brake calipers would be involved in any wheel removal and re-installation.
I plan to bring it back to the shop but was hoping for some advice first.
Thanks for any replies.
Nick S.
Nick S.
