2005 R 1200 ST Instrument Pod
terrym
The LCD screen on my ST goes dark when exposed to sunlight. Is it possible to, or is there a company that can, repair or replace the screen?
To be a little more specific, it doesn't appear to be a contrast issue, the edges and corners are fine, the area in question is semi oval shaped in the center of the screen.
One of the rubber buttons adjusts contrast. Short of that, the cluster is an assembly and just trying to open sealed module is sketchy. Haven’t heard of one being repaired.
Second on the welcome to the forum!
Did you mean the cluster is an assembly, or the assembly is a cluster??:)
