• Welcome Guest! If you are already a member of the BMW MOA, please log in to the forum in the upper right hand corner of this page. Check "Remember Me?" if you wish to stay logged in.
    We hope you enjoy the excellent technical knowledge, event information and discussions that the BMWMOA forum provides. Why not take the time to join the club, so you can enjoy posting on the forum, the club magazine, and all of the discounts and benefits the BMWMOA offers?
    Want to read the MOA monthly magazine for free? Take a 3-month test ride of the magazine; check here for details.
  • NOTE. Some content will be hidden from you. If you want to view all content, you must register for the forum if you are not a member, or if a member, you must be logged in.
2004 R1150RS 47k looking for main ground
MOONDOG59
Active member
Happy Labor Day all. Looking for the main chassis ground as pictured in the wiring diagram. It has six wires to it but doesn't show where it is. I am t/sing a no start issue and checking a bunch of switches. I just checked the side stand switch. Looks ok. Where is this main ground?
Toggle the kill switch a few times with the key in the on position and the starter button depressed. Make sure it's in neutral.
Under the battery/abs frame on left half of the engine case.
A bit tedious to get at.
That's what I figured. Can't get there from here. If it was easy to get to I go for it but everything I have done so far tells me the ground is "ok". Getting good spark at the plugs and injectors are getting electricity. I got the tank pulled apart and has it was going back together I pulled the pump screen off by accident. That's another $85.
This started as "it died on me" then to "it won't start on me" now I got to get back together. Changed the fuel filter, I know the primary plugs work. I need to test the pump and injectors. I have removed and cleaned a bunch of electrical plugs. HES needs to be looked at but doubt it is that. Can the HES be "ohm'd" out with out digging it out? Will it show a short if HES component wiring is grounded somewhere?
You are getting spark.
You have power to the injectors. They sink to ground thru the motronic.
Pull 1 injector out of the TB.
Are you getting a fuel squirt on cranking? Y/N?
If no, it might be the lower sensor
If yes, then do the following
Rotate the crank by hand to a little before the 'S' mark (5° BTDC) on the flywheel
Turn the ignition key on - the fuel pump will cycle normally for 1 sec
Rotate the crank very s-l-o-w-l-y CW by hand until the fuel pump cycles again
The crank is now at the hall sensor trip point - in this case that is also the static timing point
Look at the flywheel marking to see where the static timing is set - should be "OT"
This will test if the HES timing cup has slipped
Got to get the tank back on but waiting for a flimsy new fuel screen that accidentally got yanked off. :banghead
