I am wiring my 1975 R90s and I hope I never have to do this again. Most items seem to work correctly but the following:
The brake light comes on when I turn the key on but goes off when I press the rear brake switch.
The headlight does not go on with the key but the flasher switch will make it light up.
In the headlight I have 2 wires that I have no idea where they go. One is a green/red wire that I know it is part of the brake light. Just not sure what to do with it. The other is a yellow/white wire (thicker). It seems to be a ground.
Can anyone tell me where these wire go or point me to some pictures?
Thanks for your help.
Todd
UPDATE:
My eyes hurt looking at the wiring diagrams..
I solved the issue with the yellow/white wire. It went into a relay.
The green/red wire still doesn't have a place to go.
I think the brake light issue may be tied to working on the brake master cylinder. I don't have fluid in the reservoir yet. What do you think?
Todd
UPDATE:
