rall275
I am rebuilding the front and rear brake calipers on the 1995 and each of the fronts use a small o ring seal. The rear caliper is a little different and it appears to use two of them, though I can't recall seeing two and the schematics do not show two. Does it only use one, and if so, which side?
Photos of the two halves of the caliper. Arrows show the locations where o-rings appear to go. I should have paid better attention when I disassembled.
Thank you.
Thank you.
