'14 RT Side Case w/remote key fob
jyoung
My right side case will not open if it is on the bike. Once removed from the bike, it works per normal operation; the latch lever pops right up and opens the case. The lock itself seems normal as it will lock/unlock the release button properly while off the bike. Again, while on the bike, the side case is unopenable.
Anyone else seen or dealt with this problem?
Does your RT have the central locking option?
If so, you either have to unlock the cases and the glove boxes using the button on the key fob or the unlock button on the right hand grip.
Thanks Bernie for reply. Yes, its the central locking option. The key fob and unlock button operate other locks properly, including the left side case. The right side case will not open unless it is removed from the bike. I assume there is some interlock mechanism that is used for central locking and it is malfunctioning?
Thought the issue might be more universal and known solutions discussed, but it appears I may be the only victim of the malfunction.
Thanks again.
Is it possible that the wire for the central lock for the right side case has been disconnected in the locked position.
With both cases removed, look if the locking pin is sticking up, next to the front mounting lug.
If it is, check from underneath to check if the wire plug has been disconnected.
With the cases removed, if you actuate the locking button on the right handlebar, you should see the pins stick up and go down.
Otherwise check with your dealer about either replacement for the motor, or remove the central lock motor and use the key.
For what it's worth, the problem is resolved. Disassembled the side case to access the mechanism. Found a plastic-on-plastic pivot point in the linkage that was not moving fully to the unlock position. The entire mechanism uses a light grease for lubrication, but this critical point appeared fairly dry. I used white lithium grease and a small brush to re-lubricate the pivot point and tested with just the mechanism only on the bike. It worked as designed and I reassembled. All appears to be good (for now).
Thanks for your suggestions and interest. Be safe.
