HolgerCaban
Beemerjoy
I took the bike (2007 R1200RT) out for some early season commutes to work last week. As I was attempting to open the left side case, there was a snapping sound as I pulled on the lever. Case is not opening now. The lever pops up when I push on the keyhole button, but then nothing happens. I also can't use the key to remove the case: the key turns, but the mechanism does not respond. So, at this point the case is stuck on the bike.
My mechanic has not encountered this issue and, anyway, is on coronavirus self-isolation, so he won't see me right now.
Has anyone encountered this? How can I get the case off the bike?
If I need to cut the case off, does anyone have a source for a used case where the mechanism works - even if the lid is damaged?
Thanks in advance for any ideas.
