Previous owner had a GPS? Looks like the aux power lead that if not used is secured to frame in that location.
It's the GPS connector. Provides ground, switched +12V, and a speed signal. The matching plug is part 83300413585 if you want to tap into it without a BMW GPS. It is on the same circuit as the accessory socket(s). Tape it off to keep it dry you are not using it.
