cateyegreen71
Having trouble getting the battery out of a 1975 R90S. I can’t get it pass the frame, any tips? Well, after reading battery again post I think I have the information I need. Thank all of you for your input.
Welcome to the forum! As Paul said, remove one or more of the bolts holding the sub frame on. Also, I've had to loosen or even remove the nuts that hold the battery box mounted to the rubber bumpers underneath. Along with removing one of the upper attachments for the battery box, it allows me to tilt the box towards the rear, given me a better angle to get the battery out.
Number 16 in this picture:
https://www.realoem.com/bmw/enUS/showparts?id=0278-USA-03-1975-2476-BMW-R90S&diagId=61_0212
Never really tried the forward through the airbox approach...seemed like too much has to be removed to make that work. But certainly an option.
True for the '80 and later bikes. But the two-piece aluminum airbox and round air filter on the '79 and earlier models it was a one-bolt piece of cake. He has an R90S so it is simple.
