m_stock10506
Well-known member
How much is too much? I just replaced the brushes on the charging system of my 1984 R100. It has a new adjustable voltage regulator. It was set to limit the voltage to about 13.9-14.0 volts. I adjusted the setting and it is now maxing out at 14.4 volts. The battery is a sealed AGM.
Is 14.4-14.5 volts okay to run with?
