What problem or function are you attempting to resolve or change via the expensive IR plugs? I just bought a set for my K1300GT, $55 for four plugs at O’Reilly’s, almost double that if purchased through BMW. But that bike has plugs buried deep inside the engine and requires removal of a lot of hardware, including the radiator, in order to get at the plugs. So there, a potentially longer-life plug makes sense. Plugs on a brick-k are so accessible it seems to me you’d be better off with more frequent plug changes using less costly plugs...
Best,
DG
No serious problem being experienced. Just curious about others' experiences.
If I did have to single out one desired improvement, it would probably be improved fuel economy. I've read reports of K12RS riders getting well into the 40 MPG range. Mine does 38-39 consistently. Worse when the plugs are 10k+ miles old.
