So you pulled the whole rod out...the long piece? I'm guessing you did this with the transmission still in the bike by pulling the rod out the back, hence pulling the swingarm? My experience is that's not the way to do it. I think it's much better to pull the rod out the front which means the transmission has to be out of the bike. I've found it virtually impossible to put the rod in from the back and get the felt to remain in place. If the rod/felt is put in from the front, the felt remains in place as the rod is moved into position.
Are you still working to get the swingarm back in place? Snowbum discusses the swingarm here:
http://bmwmotorcycletech.info/inputsplinesthrowout.htm
This requires a modified socket to fit inside the frame tubes. And also requires two versions of a torque wrench in order to get the preload right on the bearings.
