(2016 R1200RT) Being very new to the RT I've become aware of the fact that headlight globes blow quite regularly, but haven't lost one yet. Is it recommended by forum members to carry spares, particularly when touring?
The H7 bulb is available just about everywhere and the the fact that one of the high beams comes on if the low blows minimizes any safety issues, so I don't bother carrying one.
Ski
I believe the springs are bent wrong? They bottom out before they can release the hook they set in. That is why U have to push in on spring center, near the hook area to release it.
My sense is that if you push ON the loops, they get stuck, in particular the 2nd side. If you push on the center area, which is arched up, you can free the loop from its metal tabbed holder.
At least you can replace an H7! The LC BMW LED headlight isn't serviceable and will set you back $2000
I recommend Philips Vision Plus bulbs as replacements. Good output and long bulb life (300 hrs). Check out the specs here
