I am looking for non working cores to experiment rebuilding the ABS III. I have the valves, o rings, etc sourced but need some cores. If successful I will be rebuilding them in the very near future.
I am buying the cores.
If you are having a problem
If you get a pump noise for both the front brake and rear brake than I am interested in rebuilding the unit. For the first several units (learning curve) I will do them for $250 including the freight back. You pay nothing until it is ready to ship back.
I am also looking at machining a block that will allow the unit to be bypassed but the electronics to be maintained. You will maintain speedo, cruise, etc but still have the warning lights. This will be in the $300 range and use your electronic.
