beemerphile
My Generac generator is another matter, it constantly charges the battery with a true trickle charge that boils the battery. I’m trying to figure out how to rewire the controller so I can use a MinnKota there too.
The trickle charger killed the battery on my Generac. The trickle charger was located inside the transfer switch. I simply removed it and replaced it with a temperature compensated maintainer located inside the Generac enclosure where the battery is. I wired the 110v for the charger back into the transfer switch and powered it from the same place the trickle charger was powered from.
