I need the axial dimension of the two EXTERIOR (visible) Spacer Bush's that bracket the wheel bearings between the front fork sliders? The LEFT Spacer Bush seems to be the bigger one and the the RIGHT one somewhat smaller. I need to put my front wheel back on TEMPORARILY until these Spacer Bush's pacers arrive from the factory - couple of weeks or so - I hope. I am planning on installing DIY spacers UNTIL The factory spacers arrive - at which time I will swap them out. Many thanks!
PS - Don't need either the OD or the ID dimensions of either Spacer Bush.
