Halogen bulbs in German vehicles have been clipped in the same way for decades. The fact you're unfamiliar with this does not make it bad design.
I have hours sitting in front of my 14 RTLC working on the headlight bulb. I think I can helpfully comment on this.
It took lots of practice to get this done but I was committed to installing the LED bulb. I commute year round in the PNW, had one on my GS, and appreciated the differences enough to go through the process. Way better colored light for those rainy and dark commutes in the middle of winter.
It took a lot of fiddling with the thing to get it changed out. The stock bulb should be very easy by comparison.
You need to pull up a stool and sit in front of the motorcycle looking right into the headlight. It does make it easier to visualize. I worked from the right turn signal side of things, so mostly left handed.
Reach under and up behind the light housing and turn the bulb cover to remove it. Righty tighty, lefty loosey. 1/4 turn I think.
Unplug the connector and move it out of the way.
The spring holding the bulb is latched at the bottom on both sides and pivots up and out of the way at the top. Push down on the spring and slide it outboard to unhook.
R & R the bulb and reverse the procedure. It really helps looking at the bulb from the front to properly orient it for replacement..
At some point in this process I was cussing the engineer who lost the bet and had to put the headlight assembly in after everything else was designed. A really crappy design for a part that is consumable.
As strange as it might sound, if I were a first timer changing the silly thing, I might consider it a dealer replacement item.
Good luck!
Scott
I, too, have had the fun of replacing the bulb. My big hands and that small, confined area make bulb changes a real adventure.
If BMW eats bulbs, as was stated earlier, then I hope that BMW releases a LED version of the their headlight. Low and High beam.
I replaced my Road Glides stock lens with Harley's LED and I would love to be able to have BMW come up with a replacement for their lights in that same vein.
Amen to that! Should have come from the factory with LED's like the GS does
Good luck!
Scott
