Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
I am hoping someone here has done this. Have read that the CanBus system is a major roadblock. Just want to know how to proceed?
Have a new 14 RT and used the Givi V47 topbox instead of the BMW one. TIA
I did it on my 2008 RT Hexhead. I used the rear external socket for the power. I can PM you some notes I made when I am near my laptop. I do remember scratching my head a fair bit but did get it to work so that running light, brake light and signals lights all worked. Really makes the rear end of the bike a LOT more visible.
Like many others I have used the rear power socket for the single Brake/Tail light switched power source for additional Givi Top Box lighting in my R1200RT.
Comparing information from the Haynes Manual and the Admore Kit I have put this connection map together; I used Grey (Gry) for grey instead of Slate for that colour name:
*Blue wire must be connected to continuous (switched) 12V to operate the embedded mini controller. For motorcycles with a single brake/tail light wire, connect the Blue wire to a 12V source switched with the ignition. Connect the Red wire to the single brake/tail wire.
Notes
Applying the brakes sends a continuous 12V to the lamp to cause it to operate at full brightness. When no brakes are applied, the bike's ZFE controller sends a Pulse Width Modulated signal to the lamp... 12V for about 3 milliseconds, then no power for about 9 mS. This repeats endlessly, resulting in the lamp glowing at partial brightness.
