Today, I noticed when I was in 3rd. gear going about 45 mph., and holding the throttle steady, I had a constant surging that didn't go away until I rolled on the throttle or, shifted gears. Anyone else have this issue?
Mine has a surge with neutral or slightly trailing throttle, low load conditions, 3200-3800 RPM in the lower gears.
Basically, it's a pain to ride in a town with a 25mph speed limit or in stop and go traffic. You can accelerate through the surge smoothly, but if you have to hold a low and constant road speed that puts you at 3200-3800 RPM in 1st or 2nd (and sometimes 3rd) gear, the bike bucks a little, like a 4-cylinder bike that's misfiring on one cylinder.
My theory is that it's just lean surge. I've fitted an AF-XIED lambda manipulator kit from Beemer Boneyard, and it's helped but not cured the problem. I'm running it on setting 7 for now, which is just 4% fuel enrichment. If it still surges after the BMSK is more fully adapted, I'll try setting 8, which is 5% (lambda=0.95.)
The bike runs much nicer now at low RPM, by the way. I find myself using higher gears with satisfactory performance down to about 2500 RPM.
I hate to mess with the bike under warranty, but I really need it to be smoother than the way it was around town. The extra power is a bonus.
Cheers
I think I have your clone. Please keep us posted on the Af-Xied results. As you know, they want a lot of money for that kit and I want to make sure it works before I go that route.
Cold start data log for stock sent via email
... [then later] AF-XIED units received.
On my 2013 K16GT I noticed that when I am modulating a constant speed, in any gear, where the throttle is barely cracked the engine seems to surge. In other words; For example, before entering a turn, I may roll off throttle, use engine compression & a little brake to reduce speed and then just crack the throttle to maintain speed until I apex and then roll out of the turn accelerating. It seems that the fly by wire system gets confused with a repetitive cycle of sending some fuel and then choking it off producing a sensation of acceleration followed by engine compression. It screws up my line in a curve and can be startling when modulating speed in slow traffic. I am either accelerating or decelerating but no in between.
The last couple pages of this thread have some updates on the AF-XIED for BMWs on Wetheads. Feel free to ask if you have any questions.
RB
http://www.advrider.com/forums/showpost.php?p=26741298&postcount=1468
Hello Rod,
Thanks for the suggestions.
I doubt "intake deposits" are much of a factor on my bike. It has 4000 miles on it.
I'm aware that a narrowband O2 sensor is more of a "switch" than a wideband O2 sensor. However, every car and fuel injected motorcycle does not oscillate at steady throttle settings. People would find that unacceptable.
Thanks again, Tom
