Welcome, Guest! We hope you enjoy the excellent technical knowledge, event information and discussions that the BMW MOA forum provides. Some forum content will be hidden from you if you remain logged out. If you want to view all content, please click the 'Log in' button above and enter your BMW MOA username and password.
Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
Not speaking with any expertise, but my '04 RT w/ 84K on the clock has been on Amsoil 20W-50 since about 6000. I've only had it since 62K, but in those miles it's used less than half a liter. The PO changed every 6000 miles, which I've continued.
The local dealer says a good dino oil is sufficient for the engine but synthetics in the trans and final drive is advised on newer, higher performance models.
Curious why you're considering a change so late in life?
Somewhere is a lengthy thread about pros/cons of changing so late.
I had a FD leak and a head gasket start leaking on a mid mileage, but year model wise older 1100 right after trying both syn oil and gear lube. The FD quit leaking after an immediate swap back...the head gasket never stopped and I had to change it. That bike stays with the old school Non-Syn blends now and no issues in 30K since the experiment.
