I purchased a belly pan kit for my 93 K75S European model and the installation is giving me some headaches.
I believe I am missing some bolts and body nuts. Specifically, I seem to be missing two body nuts that are supposed to attach to the front bracket. Without these body nuts, I can't figure how to hold the two Allen M6X30mm bolts which screw in through the centre of two large rubber grommets under the belly pan.
I looked up the body nut part number and most part depict it as #22 on the schematic but do not list it as available.
The second conundrum of the belly pan puzzle is the top bracket attachment. That's the bracket close to the radiator. There appears to be two methods of attachment, one use a grommet and another one attaches to the existing fairing.
I will post pictures later this afternoon. If anyone has some pictures available of their setup, that would be wonderful.
