Hi folks,
I have a 2002 R1150RT with the brake failure light flashing (once per second), which I think means that the brake test failed to complete. Also, the battery appears very weak, so I took the left side fairing off, removed the battery, and discovered that the acid level was below the low mark. Could the brake failure light be related or caused by a weak battery or are these two problems not related? I've had the bike only a short time, so still trying to figure out "stuff" on my own before taking it to a beemer dealer ($$$$!) Many thanks in advance!
Glenn
Glenn
