2003 K1200GT - Flashing "Brake Failure & Hazard" Warning Lights
mpsaxon
When the bike is cold the Brake Failure and Hazard lights flash back and forth. It will stop once operating temperature is reached and the bike is turned off. I had the same problem with my R1100. It was never resolved and the bike ran fine. The lights are really distracting while riding.
I heard that the problem can be caused by a weak battery or low brake fluid. I just installed a new battery and the fluid level is fine.
Any ideas?
Any ideas?
1. Have the new battery load tested after being on an appropriate charger overnight. Even a new battery can sometimes be deficient.
2. Check voltage at the battery terminal with bike running at 2500 rpm or so. Should see 14.0-14.2v if charging system is working correctly.
3. Check fluid levels in both sections of the reservoir located behind the RH panel below the seat. The inner one is difficult to see; both reservoirs have a small screw-off cap. The inner ones often get overlooked and throw a “low fluid” warning of alternating lights at 1k frequency.
4. When starting, delay pressing the starter button for 6-10 seconds after turning on the key, so self-checks can complete before starting. Failure to complete self checks can result in error lights.
Your issue sounds most like a low-voltage situation at startup, common with bikes that don’t get ridden frequently or far. But, the above checks should eliminate the two most common issues causing flashing lights on iABS bikes. If the problem is low voltage it’s common for the lights to disappear if the bike is ridden for a few mikes then powered off and restarted.
HTH,
DeVern
flashing ABS light
Did you figure it out? I had the ABS light flashing, first I thought it was the battery. Replaced it.. still flashed. Removed the rear caliper. Thin brake pads. Replaced those. still it flashed. Finally when getting home from a 2 week trip with all this stuff going on.... rear brake pedal. if the microswitch isn't properly turning on the brake lights? Now when the rapid flashing ABS light I push up on the brake pedal. Slows to a second per flash. :heart
2003 BMW K1200RS
Tim Lindstrom or hfbmw
Columbia Heights, MN
2003 BMW K1200RS
You have iABS on your bike and apparently still have a brake issue. From http://largiader.com/abs/absfault.html:
iABS fault codes
These should be listed on a sticker supplied with the bike or a table in the Rider's Manual.
Gen OFF, ABS ON = Only residual braking in both circuits.
Gen OFF, ABS flashes at 1Hz = ABS not available. Pull-away test not completed.
Gen OFF, ABS flashes at 4Hz = Only residual braking function available in both circuits. Self-diagnosis not completed.
Gen ON, ABS off = Tail light/brake light defective.
Gen ON, ABS flashes at 1 Hz = At least one brake circuit without ABS.
Gen ON, ABS flashes at 4Hz =At least one brake circuit in residual braking function mode.
Gen AND ABS flashing alternately at 1Hz = Fluid level in Integral ABS too low.
Sounds like the microswitch on your rear brake pedal needs adjusting or replacing. Try pulling up on the brake pedal BEFORE you start the bike, since if that switch is activated at startup the self-check may not complete properly. If you are still getting warning lights after starting off, without touching the brakes, the chart above should help pinpoint where to look next.
Best,
DeVern
