maybe for an off road bike but i don't think that is this machine's intended purpose.
hey, the only dumb question is the one you don't ask.
Be nice if the belt was offered as an option or a retrofit kit. I'd like to belt on my wife's GS since it will be her road bike.
At this point in time, belts of a reasonable size cannot handle as much power as chains. Slap a belt on a S1000RR and it would fail.
PS: You can actually carry a spare drive system on tour with you in your tank bag!
Best bet: The Belt. As for "Can it handle transfering fistloads of power to the rear wheel or accomodate large tires?" , I think Kawasaki (Vulcan series) and H-D (nearly their entire line) have answered those questions.
But, the idea that BMW has apparently managed to "design in" drive shaft failures, is pretty amazing.
I dunno Kevin, when I see road tests of the large engined cruisers, I see quarter mile times that look pretty meek compared to any 600cc sport bike. Come to think of it, none of those bikes are much in the leaning into corners arena either, so a huge sprocket and wide belt don't make much difference to them.
Belts are generally a lot nicer than chains, but none of the manufacturers seem to trust them on really powerful machines.
It does seem a bit odd that the drive shaft issue has been going on for some years. Every car and truck I can think of has wheel bearings on only one side of the wheel and bearing failures are rare on both cars and trucks. Seems like someone BMW knows should be a wheel bearing expert.
in the case of cruisers, "power" means torque, not hp.
have you looked at the back end of most modern large-engine cruisers? those tires are mega-wide!
back to the original question- belts are not a good plan in an environment where a rock can get wedged between belt and pulley. Results could become rubber and metal shards everywhere, but no belt in sight. So- not a plan on a GS bike.
For the R model - i dunno, belt should have been just fine.
