E
eric11
While trying to dx my cold starting issue, which turned out to be corrosion on the points plate, it seems that my cam shaft is bent. the timing is set best as possible and the bike runs great. I was going to do the push rod seals this winter.
think i should do the cam shaft as well or just leave it all alone as the bike is now running well.?
