Well, seems it's time to replace the clutch on my GS. 85,000 miles and the clutch is slipping, mostly under 5th gear when I punch it. Also every once in a while under a load I'll get a chunk/major slippage (different then the clutch slipping) from what seems to be the rear, not sure what that is but the rpm's stay the same when that happens. Any clues?
I've replaced the clutch on my 93 K75, but I know the 95 GS is a different beast. I thought I'd follow my clymer manual, but aslo want to lube all splines as well.
Anydetailed information, links to sites etc. on doing this procedure is much appreciated!!!!!
Can I use the same guide pins for the tranny as I used on my K75?
Thanks,
Andy
Thanks,
Andy
