I have an 02 R1150R. Just bought it this spring, It has 3K on it. This AM I started it and all the warning lights went nuts. I turned it off and restarted it. I heard a frying sound and was engulfed in a thick cloud of white acrid smoke. Went of work in car. A little while ago I pulled the fuze/relay box under the seat. There is a wire, bare and burnt in half and melted into a dozen others. It blew 2 ten and one Four amp fuze. And strangly, two other fuzes that check out ok are missing the clear plastic window on top, go figure. A couple of months ago I installed a set of Moto lights They and the bike have worked flawlessly till now I cannot think how the lights could have caused this problem. They have a seperate fuze and relay. I tapped into the lisence plate light hot wire to power the relay. The hot wire is brown and the brown wire at the scene of the meltdown is intact and unmelted Called dealer and he is to get back to me as to when he can drag it to shop. The thing is a mess
Questions;
Can they repair without replacing harness?
If they need to replace harness can they just replace the half that runs from the relay box rearward?
and the dreaded question; anyone know how mucho this melt down could end up costing?
I love this bike, and I hope no one else out there suffers this.
any info would be appreciated
Questions;
