Ok I need some guidance....I have checked and rechecked all the usual suspects when it comes to engine noise, but I cannot seem to find what is causing the right side to be so loud? Left side sounds great, and right side matches everything as far as we can tell.
Valves have been adjusted to spec, rocker arms are nice and tight with the tiniest of movement and oil seeping out, pushrods are not hitting the walls, exhaust is tight and no leaks, etc.
BTW bike has 45K miles on the clock and is running really well otherwise.
Thoughts?
Video of both sides......
https://youtube.com/shorts/pdmJLf0FnSU?feature=share
And up close and personal with the right side...
https://youtube.com/shorts/tPjtvubQUGc?feature=share
Many thanks in advance!!!
Thoughts?
