Mirror mounting rubber insert
dennisemanuel
Hi anyone have any ideas how I could get the insert that holds the mirror on my 2007 F800ST ? It's a 5 mm screw and the insert goes into the upper Tupperware that holds the windshield. Went to the dealer and they could not find it on the parts phish.The plastic has a square hole for the insert to fit into and I can see a brass square nut surrounded by rubber on the good mount.dennis
Are these any help? These pics are directly from the MAX BMW parts fiche. The "trim panel upper" is in section 46 (frame, fairing, cases) and the mirror assembly is in section 51 (vehicle trim).
