troymessina
I have a broken rear turn signal and cracked tail light casing on a 2001 R1200C. I've glued it back together three times in the past 7 years. I hope it holds this time. A new replacement is about $850, and I have not been able to catch a used one before it sells. Does anyone know if there are aftermarkets that fit hole pattern on the back fender?
Thanks!
troy
Thanks!
troy
