Yes, there is supposed to be a clip. 46 63 1 455 071 SPRING $6.54
Sometimes the plastic that holds the clip gets broken by people trying to remove the panel without knowing how to do it. Epoxy can repair that.
Mine has a plastic "hook" that snags the rubber "tube" at the bottom. If it busted off then I'm sure something can be cobbled together to do a workable fix.
BB
elastic cords with hooks on each end. Also known as bungee cords.What is shock cord?
Shep
Here's what the panel looks like on left side with tabs. This is from a 1991 K75RT.
