Preparing the R90/6 for the winter rebuild/Seibenrock kit. It was down on power and also smoked quite a bit on start up. Compression was 145 psi on left and 125 psi on right.
Today was disassembly day. Everything actually looked pretty darn good. The best news is that the smoking and reduction in power question was answered right up front; ring end gaps on both cylinders were close to .030" on some rings. The real problem I'm having is trying to make a good evaluation about the valves and the valve guides.
Both intake valves, valves guides and seats are all in good shape. There is hardly any play or "wobble" in the valves/guides. The exhaust valves are more problematic. The seats and faces don't look bad at all and could probably just use a good lapping (I'm probably going to regrind though). However, I am having difficulty gauging clearance between the exhaust valves and their guides. Sitting loose in their bore, there is a good amount of "wobble" or lateral movement. Both exhaust valve stems measure 7.94mm and 7.93mm. Any tips on measuring the I.D. of the guide so I can determine clearance?
Do the valves need replacing? Should I replace the valves and valve guides together? Is it possible to get a valve guide slightly undersized and hone or ream it to size? What would the BMW gurus do?
