Hi !
Upon the restoration of the 1987 K75S, it failed the compression test on the cylinder #2. puzzling is the fact that the engine was idling very smooth, plenty of power ( goes at 110 mph no problem), no vibration at any speed. The bike starts on first quarter turn. No smell in the exhaust, no oil consommation, no fumes.
Really puzzling...
But on cylinder 2 the compression was 40 psi, then 0 psi on the second go around. The engine was at operating temperature, throttle wide open. Cylinder 1 and 3 were 125 psi. The bike has 83 000 miles.
So I did this : removed the valve cover, made very sure with cam position that both valves (intake and exhaust) were closed, then push compressed air in the cylinder. Sure enough, there was a major leak in the exhaust port...
Is that a burned valve ? And what do I do with that, buy a valve, valve guides, valve seals and get the head rebuild ? Or should I just buy a known good used head. And if this, how do I know it's good if off the bike ?
Thanks for any help,
Ignace Speybrouck,
1987 K75S
1989 K75
Both undergoing a frame off restoration
1976 MGB (backdated to look like a 1969...)
1988 Mercedes 300E
1998 Mercedes E320
Really puzzling...
Ignace Speybrouck,
1987 K75S
1989 K75
1988 Mercedes 300E
1998 Mercedes E320
