Olsensan
These are the parts and numbers ordered for the 02 1150RT from Max BMW. For your reference anyone doing this job will at least need these parts with the exception of the clutch slave shaft.
* Recommended parts
Part Number Description
23211230440 FELT RING (for clutch slave rod) (1)*
21527659113 ROD - L=270MM (clutch slave rod) (1)
13641437474 O-RING - 7,52X3,51 (o-rings fuel injectors) (4)*
23417650149 BUSH (foam bushing for shift lever/linkage) (2)*
13541341797 O-RING - 52X2 (o-rings for throttle bodies) (2)*
21522335061 OUTPUT CYL (Slave cylinder) (1)
Here are a few questions:
1) Given the bike is 10 years old, seals start to fail etc, how do you guys feel
about replacing the input/output shaft seals?
2) Is there a way to check the clutch plate thickness to record wear?
3) When I pulled the FD there was oil in and around the rear boot, which
seals are associated with that for replacing?
* Recommended parts
