Without seeing it I would say DON'T bend the tabs back. I sure would not if it is as bent as you make it sound. I would consider a new rear sub frame or taking the one you have to a good frame guy to fix it.
I don't believe the tabs where the nuts are located is a stress bearing joint. I believe all the weight on the rear sub-frame is carried by the four hex bolts and the transmission they attach to. I believe the bolt with the nuts on each end justs holds the rear frame in alignment with the front frame. It's too weak for much else. I'd try to straighten it.
Or you could drill the hole bigger so their would be enough play that you could still line the other four bolts up, and just get washers for the tab holes so you could still tighten it. that might work. But I think you should be able to straighten it if you get it off, you could postion it against something and smack it with a hammer and flaten it, I would think.That's a good point. I might even just hacksaw the thing off, but I'm a butcher.
I don't believe the tabs where the nuts are located is a stress bearing joint. I believe all the weight on the rear sub-frame is carried by the four hex bolts and the transmission they attach to. I believe the bolt with the nuts on each end justs holds the rear frame in alignment with the front frame. It's too weak for much else. I'd try to straighten it. The problem will be messing up the alignment for the front hex bolt that attaches the frame to the transmission. If it isn't lined up perfect, it's very hard to start the bolt. Good luck and don't feel bad. We all have similar stories and learn from them.
Here are a few shots, the rear frame is fixed. The tabs have been bent to their original positions. A few questions:
1) Do I have to remove the entire battery box?
2) When I remove the clutch slave unit that is connected to the bleed grub
screw, does this thing leak or anything like that?
3) I'm looking at the gear shift unit, on the rear of the transmission case
(this is before pulling everything out) has anyone just removed this rather
than trying to route the connector under the battery box?
Man, I really do love this site and the MOA! With the battery carrier, I loosened the 2 - 10mm nuts holding it down, which is supported by those 2 pillon posts underneath. That is sufficient to pry the battery box up high enough to clear the tops of the bolts which the nuts came off?
