This is interesting
B
BUBBAZANETTI
So, i remembered something last night that i'd forgotten about from before the rally.
I had my valve covers off, doing the valves and i figured, "40,000 miles, i might as well do a rocker arm end-play check" i pulled up the ADV article and got to work. 3 gaps were perfect (all around .07mm) the exhaust rocker on the left cylinder was a wee bit tight (the .05mm gauge would squeez in, but just barely) so i figured i had the time, lets get this right. i pulled out the unused T45 socket from my tool chest and discovered ALL of the torx nuts on both heads were banged up to the point i couldn't insert the socket.
what could this possibly mean??
the bike had 3900 miles on it when i bought it in 05', what could someone have possibly done in that short an ownership period (miles, not years, avg to 650 miles/year) to have caused this?? my guess is someone loosened the assembly using a hex key that "kinda fit" thereby damaging the bolts. but why would they have done it???
what say ye???
what say ye???
cuz they had the hex keys, but not the Torx bits. somewhere, somebody (either the PO, or more likely some dumb tech at the 600 mile retorque service.) screwed up.
why would the 600 mile retorqe require touching any of the rocker arm mount bolts besides the one that is an actual head stud?
it's quite odd
Maybe the rocker arm endplay was out of spec at the 600 mile....it too should have been checked....
not according to the BMW factory service schedule i have
not trying to be a pain, i'm really just wondering why someone would play with these in such a rough manner so early on in the bike's life
Because they want you to sell the bike.
:hide
Erin is reminding me that I've got a few too many projects going on right now. I'm working on her. There's a nice R100/7 available for kind of cheap nearby...
Why not? You've already completely rebuilt a K75S...... :laugh
i...discovered ALL of the torx nuts on both heads were banged up to the point i couldn't insert the socket.
I think it means that some hamfist used an SAE sized Allen instead of a metric wrench.
I found that metric Allen wrenches fit a Torx head in a pinch....
Sully
