hillbillync
1994 R1100RS
I purchased this motorcycle and found out it had bent exhaust valves on the right side. I marked/wire tied the cam sprocket to the chains on both sides, pulled heads and had complete valve jobs done on both heads. I even made my self a note to signify that the left side valves were on "crossover". Some months have passed since the heads were pulled and rebuilt. This weekend I began installing the heads and attempting to set the valve clearance, I realize that I don't know where to start since the rockers were removed during the rebuild. I can't trust the old "one side has loose rockers and one side doesn't".... The kicker is I don't know why I wrote "crossover" down and went thru all my pages and videos I watched before starting the teardown and can't find that phrase again.
Assuming the cams wound up in the correct position after the tear down / rebuild since the sprocket was wire tied to the chain, how to I determine which side is on the compression TDC? Crossover doesn't sound like compression so if I noted the left was on "crossover" then should I assume the right side is on compression and start there?
I just want to get this old girl on the road again. She deserves better than collecting dust in my garage. That's what the treadmill is for...
