As I get older, it seems that more squeaks and other noises are coming from my rear end!
Somebody had to say it....
A lower shock mount bolt at the telelever that needs greasing will squeak.
it's not even that complex. The upper end of the shock at the front has some kind of a collar or the shock bushing that gets "unlubricated". I got a spray can of 3 in 1 lubricant and a long nozzle tube and did a couple of squirts at the top of the shock and at the upper pivot point. No more squeak. I don't know if it is the wiper for the shock or the upper bushing rubber but I haven't had the problem again.Well known issue on most older model K16's. Seems most guys have used SiliKroil lubricant on the front end and have eliminated any squeaking.
You can probably find it online or at your local john Deere dealer.
