brook.reams
B Reams
1983 R100RS Install Flywheel
Folks,
I show how I install the flywheel, aka, "clutch carrier". I also show how I prepare the flywheel before installation, including
<a title="Bath Time" href="https://www.flickr.com/photos/brook-reams/48906224528/in/album-72157711348300107/" target="_blank" rel="noopener noreferrer" data-flickr-embed="true"><img src="https://live.staticflickr.com/65535/48906224528_ee7cf50774_c.jpg" alt="Bath Time For the Bell Housing and Flywheel with Engine Degreaser" width="800" height="600" /></a>
Bath Time For the Bell Housing and Flywheel (in Pan at Right) with Engine Degreaser
[<a title="Cycle Works Front Bearing Carrier Puller Used To Push Crankshaft To Rear" href="https://www.flickr.com/photos/brook-reams/49341475998/in/album-72157711443881342/" target="_blank" rel="noopener noreferrer" data-flickr-embed="true"><img src="https://live.staticflickr.com/65535/49341475998_aff1f04f6d_c.jpg" alt="Cycle Works Front Bearing Carrier Puller Used To Push Crankshaft To Rear" width="800" height="600" /></a>
<a title="Flywheel Hub-Note Grooves in Shiny Band From Cut By Rear Main Seal" href="https://www.flickr.com/photos/brook-reams/48939563717/in/album-72157711443881342/" target="_blank" rel="noopener noreferrer" data-flickr-embed="true"><img src="https://live.staticflickr.com/65535/48939563717_2939498818_c.jpg" alt="Flywheel Guide Ring-Note Grooves in Shiny Band From Cut By Rear Main Seal" width="800" height="600" /></a>
<a title="Grooves Are Gone After Polishing Them Out" href="https://www.flickr.com/photos/brook-reams/48939562807/in/album-72157711443881342/" target="_blank" rel="noopener noreferrer" data-flickr-embed="true"><img src="https://live.staticflickr.com/65535/48939562807_df7f81038b_c.jpg" alt="Grooves Are Gone After Polishing Them Out " width="800" height="600" /></a>
<a title="Bracing Engine Block Before Torquing Flywheel Bolts" href="https://www.flickr.com/photos/brook-reams/49341691198/in/album-72157711443881342/" target="_blank" rel="noopener noreferrer" data-flickr-embed="true"><img src="https://live.staticflickr.com/65535/49341691198_a3a0d387fa_c.jpg" alt="Bracing Engine Block Before Torquing Flywheel Bolts" width="800" height="450" /></a>
You can read about how I do this work here:
I also shot a short video that summarizes the work.
VIDEO: 1983 BMW R100RS Prepare and Install Flywheel
I hope this is helpful to anyone planning to do this work.
Folks,
- Cleaning the guide ring,
- Polishing out the grooves in the guide ring created by the rear main seal,
- Dressing the teeth on the flywheel to remove ridges created by the starter motor gear engaging with them,
- Replacing the large o-ring in the guide ring,
- Cleaning the crankshaft bolt holes and bolts, and,
- How to center the flywheel on the bolts so the ignition timing is correct.
